WTF! Temp gauge fluctuating!
Old Mar 17, 2003 | 10:34 AM
E-man007's Avatar
I was overheating for a while and replaced my 160 thermostat with a new 160 thermo and it was back to normal temp for a while.Now it redlines and cools down again in a matter of minutes.Should I put a 180 stat?I dont have a coolant leak and my fan is working fine.Any advice is appreciated.
Old Mar 17, 2003 | 05:28 PM
25THRSS's Avatar
It shouldnt redline with any temp thermostat. you have another problem besides the thermostat.
Old Mar 17, 2003 | 07:05 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Maybe you have a bad temp sender.
Old Mar 20, 2003 | 09:19 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
try that
Old Mar 21, 2003 | 12:48 AM
MdFormula350's Avatar
what kinda coolant mix you running?
whens the last time you changed you rad. cap?
is your lower rad. hose collasping?
when does it get hot?
Old Mar 21, 2003 | 04:36 PM
SilverSub122's Avatar
typically you should run a 50-50 mix of coolant and water but if you dont have one get the air dam that it seems like most 3rd gens are missing i got one and it dropped my engine temp about 50*
Old Mar 30, 2003 | 10:09 PM
ryan1488's Avatar
that would be your thermostat sticking, happened to me in my truck. the one you just put in is defective.
Old Mar 30, 2003 | 10:39 PM
25THRSS's Avatar
He said he changed the thermostat and it still did it so i doubt it would be the thermostat.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
wisemanz28
Sep 20, 2015 01:26 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
