Any service required on belt clutch fan?
Old Mar 26, 2003 | 09:36 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
On the Belt driven fans they have a clutch system on the shaft that I believe allows the fan to slip if the shaft is cold and not-slip if the shaft is warm. I assume this is to help fuel economy. Does this mechinism need to be cleaned periodically (WD-40?) to run properly?
thanks,
phil
Old Mar 27, 2003 | 09:43 AM
82camaro's Avatar
Car: 82 camaro SC
If it's a thermal clutch, it 'makes' the fan spin hard when the temp sensor on the front of the clutch gets to a certain temperature. The clutch slips when it's cold. It has it's own fluid inside, no service required--just replacement when it stops working correctly.
Drone358
Dec 10, 2015 08:16 PM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
