vents not working
Old Mar 27, 2003 | 01:26 PM
Kaas's Avatar
Car: 89 Iroc-Z
vents not working
last night i was driving, and hit 85 or so and my radiator hose came loose again, i pulled over before it was able to overheat and me and my buddy got the hose back on, and filled it up with coolant. it is looking fluid a lot more than before (has a bad water pump which i am tryin to change here soon) and now the vents do not work at all, any suggestions on how to get the vents to work again?
Old Mar 29, 2003 | 11:40 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Does it blow the air up the windshield all the time? If so that is due to a lack of vacuum going into the controls.
Old Mar 29, 2003 | 11:49 PM
Kaas's Avatar
Car: 89 Iroc-Z
that is actually what's happening..how do i fix it? i found a lose very small hose coming from the top of the block (towards the windshield side under the hood, near where the carb is), but have not been able to find out where it goes, not sure if that is the hose or not, the reason i ask about this hose, is because it seems to do a vacuum type thing instead of blowing out air and such
Old Mar 30, 2003 | 11:55 AM
Connect that hose to a vacuum source, and report back.
86White_T/A305
Aug 17, 2015 12:16 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 11, 2015 03:17 PM
