Water pump mystery
Old Apr 2, 2003 | 07:42 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
Water pump mystery
Well I started noticing every once in awhile there will be a little puddle of antifreeze under my car, its not every time just every now and then. I check all the hoses and the only thing that was wet was the water pump and it was leaking down the bottom radiator hose. What is going on?? I tightened all hose clamps and it still does it. Is there water coming out of the water pump itself??
Old Apr 2, 2003 | 09:08 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
most likely it needs a water pump, I have seen them as cheap as $15 at murrays
Old Apr 2, 2003 | 09:21 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Yeap! Water pump. There is a little hole on the pump, that when it is worn out it will leak. Time for a new one, not to costly and easy to change...
Old Apr 2, 2003 | 09:25 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
ok, thanks I got an extra one in the garage guess I need to get off my butt and change it.
Old Apr 3, 2003 | 11:36 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
The small hole in the pump is there just for the situation you are having. Why not use this time to get an aluminum piece? Just a thought.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Dialed_In
Aug 20, 2015 01:45 PM
