will this engine run hotter than stock?
Old Apr 11, 2003 | 02:12 PM
worldofool's Avatar
I'm am wondering if I will require better coolong than stock with this engine.
355, AFR 190, Superram, LPE 219, 10.3 to comp, Coated headers.
I live in the desert so it gets pretty hot. My mostly stock 87 GTA 350 won't over heat now but would that engine run hotter.
thanks
Old Apr 13, 2003 | 10:13 PM
CAMAROsc350's Avatar
It might run slightly hotter but that all depends on your cooling system. When i swaped out my 305 for the 350, i put in a new radiator new hoses,water pump 180degree thermo and a fan switch that kicks the fan on at 200 and off at 185. It runs way way cooler than the 305. Put a lower temp thermo, get your fans to turn on earlier and check the rest of your cooling system. If you feel its neccesary upgrade your water pump but i doubt youll need to. Hope this helps
theshackle
Mar 5, 2017 06:37 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Jae992
Aug 27, 2015 09:07 AM
camaroken83
Aug 10, 2015 11:35 AM
Exxon Limited
Aug 9, 2015 08:13 PM
