What can cause a radiator leak?
Old Apr 14, 2003 | 03:46 PM
SomeDodgeGuy's Avatar
I seem to have a pressure leak of some sort.. on the right side of the engine, at the corner of the radiator. When the car is hot, it pours steam out all over my battery and right side headlights.
Before I go out and get some expensive alluminum billet hyper flow radiator, I must know what could cause this leak so it doesnt happen again.
Any ideas?
BTW, 92 RS, 3.1 MFI, 5 speed, yadda yadda. I usually keep a correct balance of coolant and water in the radiator, but the past few days it has been straight water because im out of coolant.. (im such a bad boy.) The cap has been pressure tested and it is installed correctly, and finally, my radiator hose is fine.
Old Apr 14, 2003 | 05:19 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
a hole
usually its just age, as long as nothing is toughing there and the antifreeze mix is correct,. you should have no trouble with an aluminum rad
Bubbajones_ya
Jul 6, 2024 08:32 PM
sac92transam
Oct 7, 2015 02:31 PM
Stryker412
Sep 20, 2015 06:59 PM
84redta
Sep 19, 2015 09:58 AM
blackandblue02
Sep 10, 2015 08:19 PM
