how to get cooler temps
Old Apr 21, 2003 | 09:18 PM
camaroracer1's Avatar
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
My car runs at 220 degrees with both fans on, I'm running a 180 thermostat, 176 degree fan switch at is still runs 220. I also have a manual fan switch for the second fan. I already took out the a/c condensor, new 15lbs radiator pressure cap, running a 50/50 coolant water mixture, and the air dam is still in good condition. Why can't it go below 220. The only time the temp goes down is when i'm rolling down a hill at idle. If I change the coolant to water mixture to 30/70 will it help to cool the temp down. Also I noticed that my top radiator hose is puffed up (expanded from normal position) is this normal? And when racing down the 1/4 the temp seems to rise about 10 degrees. What can I do to drop my temp?
1988 Iroc-Z 5.7 tpi
Hooker Super Comps (Shorties)
AFPR, K&N, MSD 6AL, Ram air
Best time 14.09@97mph.
Old Apr 22, 2003 | 04:51 PM
captcorey88iroczragtop's Avatar
Sounds like there may be a restriction in the radiator... if your
t-stat is open and water is flowing to the radiator, AND there is
a restriction it might cause the upper hose to balloon.
I replaced my radiator and immediately saw cooler temps, and
even cooler when i started using GM-Dexcool.
Also, another thought, is there any air trapped in the system?
by the way, my 88 iroc convertible was originally sold at the
dealership in honolulu.
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
FormulasOnly
Oct 2, 2015 05:52 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
