Where the hell is the orifice tube located?
Old Apr 23, 2003 | 12:37 PM
Makai's Avatar
I have an 86 TA. I going thru the process of converting to 134A and replacing the compressor and accumulator bottle as well as the orifice. Where the hell is the orifice located? I have to remove the old one first but I can't if I can't find it. A picture would be most appreciated as for where it is located on an 86.
What do ya want, I'm a chic!
Thanx guys
~Marie~
Old Apr 29, 2003 | 06:10 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
it's located to the left of your accumulator(dryer). it's inside the smaller aluminum line. just open up the line and look down inside. your orifice tube is in there.
Old Apr 30, 2003 | 08:37 AM
jeffs82z28's Avatar
Dude, I know where the orifice tube is, and your description confused me.
Makai,
The orifice tube is in the bottom port of the evaporator.
Remove the liquid line from the condenser core and evaporator core, slip a pair of needle nosed pliers into the hole, grab onto the orifice tube and give it a twist/ pull.
Old Apr 30, 2003 | 12:41 PM
Makai's Avatar
found it
Ok guys, no need to argue over who's right. We found it the other day. On the 86 TA, it's in the line that runs under the accumulator/drier bottle at the firewall end of the line. (not the radiator end)
Oh and Jeff, I have to agree with you about 2nd shift totally sucking!
z 28 jari
Sep 14, 2021 10:03 PM
earlpote
Sep 12, 2015 11:55 AM
dimented24x7
Sep 6, 2015 03:51 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
