Too hot in car
Old May 13, 2003 | 09:21 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Too hot in car
Why is it that every time I drive down the road for about 10-15 minutes, it starts to get hot inside the car. My heater is off and still gets hot in my car. I cant stand it any longer. please help!!!
Old May 14, 2003 | 07:01 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Two things come to mind. With the heater off check at the water valve. The hose going to the heater core should be cooler than the other 2. It may be gummed up with junk causing it to stay open thus circulating coolant through the core even with the heat off. The other thing, feel the pass side floor. Radiated heat from the catalytic converter will warm the passenger compartment somewhat. Make sure the heat shield for the cat didn't go bye-bye.
Old May 14, 2003 | 02:20 PM
warrior_91's Avatar
Car: 86 T/A
Does it have anything to maybe do with the little black chin spoiler that mounts underneath the radiator. My car doesn't have that spoiler and its critical for cooling isn't? The car doesnt have any grills so all the air has to be collected and sent up through the radiator by that spoiler.
Old May 15, 2003 | 06:27 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Thats the airdam, and yes it is absolutely critical for proper radiator cooling. Without the airdam the TG's will run much hotter and the fan(s) will constantly be on. It is the primary source of airflow to the radiator when the vehicle is moving. They run about $25 at any GM dealer.
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 11, 2015 03:17 PM
86Base
Aug 8, 2015 01:34 PM
