Water Pump?
Old May 15, 2003 | 01:09 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Water Pump?
What kind of water pumps do out cars use? Im wanting to look on Ebay to see if I can find one....
Mine is starting to leak form the little hole that the pumps have..
Old May 15, 2003 | 08:09 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
You should have the water pump designed for the serpentine belt drive. It is a long style of pump. Just make sure you get one that has the reverse rotation for the serp belt. I assume yours has the serp belt, sig said its an 87 TPI...
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
