R4 ac compressor
Old Jun 20, 2003 | 01:46 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
R4 ac compressor
I 87 GTA and I was wondering is there any differance between the a/c compressor on fuel injected cars and carburated cars? The reason I ask is there is about $50.00 differance in price but the look the same.
Old Jun 21, 2003 | 06:14 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
its not whether its carb or efi. In 87 or 88 the belt system was changed from a v-belt over to serpentine, and the compressor was moved from the drivers side to the passenger side. So the brackets and mounting points are more than likely a little diffrent. Get the compressor that is for your year and motor.
Old Jun 21, 2003 | 06:37 AM
battman's Avatar
Thanks for the reply. in 87 both carburated and fuel injected had v belts. looking at the compressor for the carburated, it looks the same as mine, I couln't figure out why the compressors look identicle but have such a price difference.
Old Jun 21, 2003 | 09:09 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Check the connectors, if they are the same you can use the cheaper one.
Galaxie500XL
Feb 1, 2020 04:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
