Coolant Pouring out HELP
Old Jun 21, 2003 | 12:24 AM
Camaro Z03's Avatar
my car has been running hot lately and today i was on the highway in traffic when my car started red-lining, so i pulled off the exit that was right next to me and i pulled over to the side of the road, as soon as i shut my car off and got out, coolant started leaking out from the bottem of the radiator at a steady pace and then it started pouring out faster until it was empty (im guessing it was empty because there was A LOT of coolant on the gound under my car) could this just be a result of my car overheating? or could it be a tank in the radiator? it looked like it was coming out more toward the passanger side of the car...any help would be great, thanks guys
Ryan
Old Jun 21, 2003 | 06:09 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Think you need a new radiator. Any parts store should have one for your car.
Old Jun 25, 2003 | 02:53 PM
K-DOG's Avatar
Not to make you sound like a retard but I always check the easiest stuff first. Did you make sure that the drain **** was closed all the way. I have had that come loose and leak little by little. Also check all the hoses, if everything is tight and closed then you might have a real problem. You got to find out where it is leaking from to figure out what you need to do to fix it.
Old Jun 25, 2003 | 03:04 PM
Camaro Z03's Avatar
Not to make you sound like a retard but i stated in the original post that it was coming from the radiator, meaning most-likely one of the tanks "you have to find out where the leak is coming from in order to fix it" no sh*t buddy, thanks
Old Jun 25, 2003 | 08:24 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
make sure your fan is coming on too.!
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
