fan
Old Jun 26, 2003 | 04:04 PM
Grimaldo's Avatar
fan
If I have my fan grounded permanately, and have it running all the time, how fast will my fan burn out or will it?
Old Jun 26, 2003 | 05:08 PM
MdFormula350's Avatar
its going to cut down the life alittle more, i wouldnt run it all the time. you should just take that ground wire and put a simple toggle switch on it so u can gorund it anytime you want. there is not really a need to have the fan running while cruising / on the highway, the car should still get good air flow.
Old Jun 26, 2003 | 05:14 PM
Grimaldo's Avatar
Yeah I realize that but how do I run a toggle switch and do I need to re wire the power source or do I just hook the switch to the ground wire. I am bad with stuff.
Old Jun 26, 2003 | 05:15 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
mine burnt out on the I5 on monday
I used it for a year (I've had it for a year) with no problems
new fan is $60 USD
Old Jun 26, 2003 | 05:22 PM
Grimaldo's Avatar
You ran it full time for a year? Did you only have one fan?
Old Jun 26, 2003 | 06:36 PM
waltersb's Avatar
I only have 1 engine bay fan
and yah it's been on for a year, on while the ignition is on.
Old Jun 26, 2003 | 06:41 PM
Grimaldo's Avatar
Why did you have it running the full time?
Old Jun 26, 2003 | 07:33 PM
waltersb's Avatar
cause I have no air dam apparently...
need to get one...
Old Jun 27, 2003 | 01:00 PM
RPM WOT L 98's Avatar
That air dam makes a big difference! I run my primary all the time bc the motor is not stock and I have a trans cooler in front of it so the trans constantly has cooled fluid going through it. The AUX is wired to a foglight switch. It only took me a week to figure all that out! Read this post
https://www.thirdgen.org/techbb2/sho...hreadid=181441
Mark
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
