Bad head gasket, or do I need an airdam?
Old Jul 5, 2003 | 09:07 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I'm having some overheating issues. I've got an L98 Trans Am and I just got the motor in it a few months ago. I can drive for about 10-15 minutes until the coolant temp gets too high (240-260). I've got plenty of coolant, a new water pump and no leaks. I've got the stock thermostat in the car as well. Only thing I don't have is the air dam. I don't have to be on the highway for it to happen, just cruisin' around town 40-50 MPH. I'd like to know if it's because of the car not having an air dam or do I need to change some gaskets. I will be getting my hands on the tester that checks for combustion gasses in the coolant, but just would like some input from you guys in the meantime. BTW, the fan does come on. It's the single fan from the L03, but that shouldn't make a difference.......should it? See my sig for mods.
Old Jul 5, 2003 | 10:09 PM
25THRSS's Avatar
Get an air dam!!!!!!!!!
Old Jul 6, 2003 | 09:29 AM
Engine: LB9/383
LOL. It's in the works. So do you guys think it's all because I have no airdam or should I be looking somewhere else for the problem? It won't heat up sitting at an idle. If it gets above 220* and I park the car and let it idle, it actually cools down.
Old Jul 6, 2003 | 02:42 PM
KC10Chief's Avatar
Get a damn dam damn it! Definately sounds like an air dam problem to me. Matt
Old Jul 6, 2003 | 03:50 PM
Nasty_Bird_'90's Avatar
dammit! I get it! I need a damn dam! Damn! LOL. I'll try to round one up and let you know how it goes. Thanx.
Old Jul 6, 2003 | 05:38 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Maybe double check your timing and make sure you don't have air pockets in the coolant system.
Old Jul 6, 2003 | 08:45 PM
Engine: LB9/383
Is there a special coolant fill procedure that requires bleeding of the coolant system? I know that the newer cars need to be bled, but I didn't know the older cars did. I though it was fill it and go.
Old Jul 7, 2003 | 05:31 PM
RPM WOT L 98's Avatar
Coolant bleeding procedure:
Open rad cap, and let car run. Heater on.
The air dam is actually quite amazing. I haven't put mine back on yet bc it's in the process of restoration, but I drove the car a little bit and with both fans on it was warming up prtty good. Yet it could idle forever. You're putting a lot more stress on an engine by driving it, and you need that channeling of air to the radiator. It really does make a big difference.
The two main things you don't remove from a car:
- Fan shroud
- Air dam
Old Jul 7, 2003 | 06:33 PM
KC10Chief's Avatar
Ever seen Vegas Vacation? "Where can I get some damn bait?!?" Uncle Eddie
Old Jul 13, 2003 | 12:48 PM
Engine: LB9/383
Well, I ruled out the airdam issue today. Haven't been able to find one yet, so I just took off the hood and drove it for a few minutes and it still heated up. I figure without a hood it will get plenty of air...right . I let it get to about 240 and brought it home and parked it and let it idle. At idle, it cools down!! I don't get it. All signs point to airdam,but........
Old Jul 13, 2003 | 05:58 PM
25THRSS's Avatar
Wrong. You still need an airdam. Without one the radiator will never get anough air to cool down the coolant passing through it. An airdamn is not hard to come by. Just get on off of ebay or the dealer. They aren't that expensive either.
Old Jul 13, 2003 | 08:57 PM
Engine: LB9/383
I know I still need an airdam, but this just proves that there is still another problem causing the car to overheat, which I need to fix
Old Jul 13, 2003 | 08:58 PM
25THRSS's Avatar
It doesnt prove anything. Even with the hood open, the radiator still isn't getting any air.
Old Jul 23, 2003 | 08:38 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Key word here is Trans Am. You have no grill.
All of your cooling comes from underneath the car. At highway speed especially you get a velocity effect where the air just rushes under the car.
The air dam "scoops" up this air and forces it into the radiator.
There are 2 important components (there are variables on these depending on different models). A big wide strip that looks like lawn edging from Home Depot.
And a molded plastic piece that looks like a shroud that directs the air into the radiator. THIS is the important piece. You can keep a car cool without that lawn edging but it's still recommended.
Both are called "air deflectors". The strip is not as important.
Lack of the air dam is not something to mess with. You might as well be running without water.
Old Jul 24, 2003 | 07:26 AM
Engine: LB9/383
I got both pieces new from a buddy that works for ACDelco. I put them on Monday night and I've been driving it ever since with no problems. Thanx guys.
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
