Bubbling sound coming from the rad cap???
Old Jul 7, 2003 | 10:33 PM
1gta2c's Avatar
Once and I while I here this sound from the rad, more from the cap itself. The car runs cool all the time. I did an anti freez test and the coolant is good. Do I need a new thermostat or a coolant flush???
Old Jul 8, 2003 | 07:49 AM
KC10Chief's Avatar
Replace the radiator cap. It's probably not keeping pressure. Matt
Old Jul 8, 2003 | 01:32 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
yeah my mom had a car do that, then it dumped dex-cool all over a wall-mart parking lot. Then some dude with ****** put it back on loose so it didn't blow a hole in the cooling system from too much pressure I was inside when the guy did it and we dumped more coolant at McDonald's. By the time we could get a new cap we put in 3 gallons of coolant and water.
Old Jul 9, 2003 | 03:47 PM
RPM WOT L 98's Avatar
If it's when the car is hot, then it's just not holding pressure probably. Need a new cap.
If it's when the car is cold, then it's normal bc the radiator is sucking the coolant back from the overflow by using the vacuuim relief valve on the cap.
Old Jul 10, 2003 | 12:20 AM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
My car did that lately and I found the problem was a leak at the water pump because of those assy oem hose clamps. I replaced all my clamps with the screw teeth kind and that did it.
91 rally sport
22
Apr 5, 2016 05:06 PM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
