Best Re-man AC Compressor??
Old Jul 10, 2003 | 09:25 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Who makes the best remanufactured AC compressor? I 've got an '88 Trans Am and my compressor's seized. It's R-12. Thanks
Old Jul 10, 2003 | 09:48 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Would this one work? Should I convert to R-134A, or stay with R-12?
http://www.pontiacautopartx.com/air_...---507238.html
Old Jul 12, 2003 | 11:20 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
I'm getting this compressor for my 305, but I plan on upgrading to a 383 soon. Will the same compressor work for both? Anyone??
Old Jul 13, 2003 | 08:10 AM
1986redbird's Avatar
the compressors don't care about engine size (cubic inches) as long as you use the same brackets, I have heard alot of argument about switching to 134A, I had it done by a professional a/c shop and I hate it, it doesn't cool worth a crap. I am considering going back to r-12 or something like it, then I have heard alot of people who switched and have great cooling, when you put in the new compressor make sure you get a new reciever/dryer and orrifice tube to go with it. they're not that expensive and will save you alot of agrivation down the road.
Old Jul 19, 2003 | 07:52 AM
Andy Bush's Avatar
I fitted a new compressor from NAPA. It seems fine.
The R134 compressor has a smaller pulley to make it run faster, also the suction pressure needs to be higher at about 40 psi, than the R12, which used to be at 20 psi.
I used a new suction pressure switch, accumulator, expansion / restriction insert. The cooling is fine.
Old Jul 22, 2003 | 11:09 AM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
I did the same thing you did and got a NAPA reman. and had 134 put in the system. At first I was really upset at how poorly it was cooling. After a short time though, it seemed the refrigerant just needed to cycle through the system a while. Now even with glass tops I can't really complain about it.
Old Jul 23, 2003 | 04:13 PM
Andy Bush's Avatar
The other thing I did was get a $60 guage set. I noticed watching the guages that I had to run the engine for quite a while before it would suck in enough refrigerant. Also I think it operates at a much higher pressure, so if the suction pressure switch is not changed out the cooling wont be adequate. It seems fine now.
Galaxie500XL
Feb 1, 2020 04:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
