Car stays kool with ac on only!!!
Old Jul 18, 2003 | 05:07 AM
dunsplus's Avatar
for some strange reason my car tends to climb in heat rather fast.when i turn on the ac the temperature stops rising and usually stays at the temp i turned the ac on or it goes down a bit.
took it to mechanic had radiator checked for leaks flushed and so on.Any tips or suggestions would be appreciated thanks alot guys.
p.s. its a 89 firebird 305:hail:
Old Jul 18, 2003 | 06:38 PM
RPM WOT L 98's Avatar
It's more than likely got something to do with you fan(s). when you turn the ac on the ECM cuts on the fan, or the AUX fan if you have TPI. When the AUX fan cuts on w/o the pri fan being on then the ECm goes into default and turns on the pri fan. So you are going from no fans to two fans and that is why it's cooling off. You need to look at the circuit that energizes your fans.
Is it a TPI or TBI car?
Old Jul 24, 2003 | 04:34 AM
dunsplus's Avatar
hey thanks fopr reply not sure if its a tpi or tbi just got the car.how canh i tell? thanks for the help ;p
p.s. i installed a 160 termosthat.but car heat still goes up.
Old Jul 24, 2003 | 06:17 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: Car stays kool with ac on only!!!
That's normal. When A/C is requested the primary fan runs all the time as opposed to it waiting to get to 220 for it to engage, with dual fans the primary is on all the time as well and the aux fan kicks on and off based on A/C pressure. They all do that, nothing to worry about.
Ghettobird52
Jul 5, 2024 11:18 PM
novaderrik
Aug 10, 2015 12:44 PM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
