Stock (but new) cooling system enough for 350rwhp?
Old Jul 23, 2003 | 01:58 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Hello,
Real quick question. Dropping in a Super Ram 355 in the next two weeks, it's at the machine shop now, and I just wanted to see what you guys felt about the stock system being able to keep temps down on this engine. I will be buying all new parts, just stock parts. Here's the list
Stock Z28 aluminum / plastic radiator
Stock water pump (though VERY strong possibility I may go with stewarts)
180 thermostat
All new hoses
SPAL dual 11" fans - I already have these
What do you think? I run the AC almost constantly and drive the so cal freeways, but everything on the car will essentially be new. I would go with the griffin stock four our cars, but too much $$$, or the griffin universal, but it sticks out too far, and doesn't look stock at all from any of the pictures that I have seen of them installed.
Thanks in advance,
James
Old Jul 23, 2003 | 03:41 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
If your not going with aluminum, at least get a 3 row. I saw a couple different ones for around 170.00 new while surfing a search "automotive radiators".
Old Jul 23, 2003 | 03:51 PM
Engine: 355
The plan is to go with aluminum. The stock radiator is a 1 row plastic/aluminum piece. You can also get a 3 row brass and copper, but thought that the aluminum , even though a 1 row, would cool better due to the heat disappation. Any thoughts?
Old Jul 24, 2003 | 02:04 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Just get the stewart water pump. Only 159.95 bucks for the aluminum one. Throw in another 10.95 for 180 thermo or drill out stock one. That pump price is the stage 2 also. It offers around 5 gpm than the stage 1. Don't freak out when you view the spec sheets and it says it might not come with aux inlet for heater hose I know for fact that the 23123 model (long sytle for serpentine) does come with it. So if you want to upgrade to a universal griffon or another radiator later that doesn't have to fitting for the heater hose return it's no problem just hook it up to the pump.
There from MI so I didn't pay any sales tax on it since I'm from IL (anyways a plus).
I plan on putting in the 180 buck griffon radiator, when my craps out. You could always look for one cheaper I think I found one for 160 one time.
Old Jul 24, 2003 | 06:20 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
I agree:
Go aluminum on the rad and at least a 3 row.
Stewart or comperable on the pump.
Water Wetter instead of antifreeze/water assuming you don;t live way up north somewhere.
Orr89RocZ
Apr 25, 2016 08:28 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
sreZ28
Aug 14, 2015 07:48 PM
Leggman1
Aug 6, 2015 04:15 AM
