Who here has a Be-Cool radiator in their 3rdgen?
Old Jul 21, 2003 | 12:37 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
I just got a nice Be-Cool radiator for my 92 RS. The stock hoses don't fit now, so what are you guys using? I don't want to use those cheesy universal flexiable hoses either.
So what fits?
BTW, I know the TPI and TBI/carbed engines used different hoses, mine's carbed.
Thanks!
Joe
Old Jul 25, 2003 | 04:16 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Be-Cool
I got the custom-fit, and everything fit perfectly. Hoses and all.
Old Jul 28, 2003 | 12:31 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
You know, in another thread somewhere, somebody said he would NEVER run "one of those universal hoses". Well let me tell --AGAIN FROM PERSONAL EXPERIANCE---those ridges you see on the universal hoses actually make them stronger than a molded hose! They will not collapse as easy! Next time you go to the parts store, ask the counter man to grab a universal hose and a molded hose--any type/any application--doesn't matter as long as it's the same diameter/same thickness--then squeeze them like if they were collapsing in on themselves. Believe me, the universal hose will be stronger, but don't take my word for it. Go do it and prove it to yourself!!!
Old Jul 28, 2003 | 01:27 PM
88blackbird's Avatar
Car: 88 Trans Am GTA
craig is absolutley right, I use to manage a auto parts store. And to add that most of the flex hoses also have wire in them looks like a spring inside the hose. If you make one of the flex hoses collapse you have a very serious prob lol. later
Old Jul 28, 2003 | 01:40 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Who here has a Be-Cool radiator in their 3rdgen?
So what fits?
Thanks!
Joe
when i put mine in, i worked at a auto parts store...
for the upper hose, i found a hose that had a bend just right to go from the radiator straight at the motors thermostat housing.... the hose i got had another bend, but i cut it off just before the bend and it was PERFECT.. nice clean straight hose..
for the lower hose, i used a universal flex one, i never found a molded hose that fit the lower one right....
i had one that was close, but it needed a slightly tighter turn then it was molded for, and that made it pinch...
Old Jul 31, 2003 | 04:14 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Watch out when using those universal flex hoses though!! I hate them.. I used one of those initially for the upper hose when I did my conversion (till I could find something more precise). The spring kept creeping back towards the radiator side leaving a very weak portion right off of the water neck... Two different ones did that to me.
Old Aug 5, 2003 | 11:57 PM
bigals87z28's Avatar
Car: Check The Sig
you can take out the spring for use on an upper hose. The spring is there so that the lower hose doesnt colapse and cramp up your cooling system. ALWAY'S make sure the lower hose has a spring.
Old Jul 29, 2004 | 03:52 AM
Kandied91z's Avatar
duke i know your still around, how did this turn out. did you have the direct fit becool or the standard generic that's close?
Old Aug 10, 2004 | 02:29 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
I have a Be-cool and I bought the one that is supposed to fit our car
It neede a little finagling but everything wrked pretty darn well.
I would just get the one to fit, thats just me though
Old Aug 31, 2004 | 12:59 AM
Kandied91z's Avatar
it isn't direct fit as they say...i'd save since you have to custom work it and get one that's similar in dimensions. i had to do alot of work to get my direct fit to fit.
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
