help car runs way hott
Old Jul 30, 2003 | 10:26 PM
jwformula350ws6's Avatar
i gott a 87 firebird formula wit a transplant 350 when im in stop and go traffic my car runs at 200 degrees when i gett on the highway and do 70 it stays the same butt when i start doin like 80 and my car is spinnin 2200 hundred rpm,s it starts to run at 240 i putt in a new 3 core rad high flow pump and 180 t-stat and it still does it and all gaskets r good and airdamn is in great shape please help
Old Jul 31, 2003 | 02:54 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
There is really not a "single" air dam on your car. Check the wide strip across the bottom front and check for the plastic scoop type mounted to the bottom of your radiator.
Both are air deflectors: aka: air dam(s)
Otherwise you might use this <A HREF="http://www.gmtips.com/3rd-degree/dox/tips/cool/overheat-1.htm">diagnostic tree</A>.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
