Fan WONT turn off
Old Aug 8, 2003 | 04:36 PM
skahide's Avatar
Fan WONT turn off
I have a 88 camaro V6 and as soon as i start the car my fan turns on. after a sec it goes off then comes right back on again. It never even get to heat up. what could it be? I have had some other problems, could these of caused it: cat was clogged, and i think it fried o2 sensor and car is running rough. thanks guys
Old Aug 21, 2003 | 12:58 AM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
seems like your straight wired but it has a short or somthing...
(i dont think any of the other could have been the culpret(sp?)) check your relays
Old Aug 28, 2003 | 09:59 AM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
Had exactly the same problem with my '88 IROC.
Turns out it was a bad temperature sensor, on the V8 this sensor is located on the right side of the block below yhe exhaust manifold.
Apparently these are designed with a fail-safe, meaning that when the switch fails, it fails in the circuit closed position.
Hope this helps
RazorN8
Jan 7, 2022 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bryanwood74
Sep 24, 2015 09:50 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
