shroud?
Old Aug 11, 2003 | 05:53 PM
icebird_1981's Avatar
shroud?
k i dont no if thats the right spelling or the right name but its the black thing that goes over the fan. anyway i only have the top pice on my 350. i got a bottom pice out of a 2.8. will it help?does it make a diffrence. also will the 2.8 one fit a 350?
Old Aug 13, 2003 | 09:09 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
If the shroud does anything at all is a pretty good question. Some say yes and some say no. If you're overheating, I would guess that something else is the cause besides the shroud. I, myself, put in a dual 11" SPAL fan setup. I can't say enough good things about this thing, and it does have it's own integrated shroud design. I just took off the upper shroud and am using a steel strap to hold the radiator in place.
Old Aug 13, 2003 | 09:11 PM
no i dont have a over heating problem or anything like that, just figure if i can make it a bit more cooler y not. but thanks for the info.
Old Aug 21, 2003 | 12:52 AM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
Kind of a stupid question But you live in Canada how do you have heat problems heheehe
Old Aug 21, 2003 | 05:35 AM
82camaro's Avatar
Car: 82 camaro SC
If the fan is real close to the radiator, you probably don't need a shroud--like an electric fan.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
randy210
Oct 15, 2015 03:43 PM
krisner89
Oct 10, 2015 06:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
