Easiest/quickest waterpump install?
Old Aug 12, 2003 | 06:10 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Everyone keeps telling me to do different things. What would be the best way to make my life easier?
Old Aug 12, 2003 | 06:20 PM
mace87's Avatar
take off the hoses, remove the bolts, and your done. it is one of the easiest things to do
Old Aug 12, 2003 | 06:39 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Yes, but people are telling me to remove my radiator, alternator...etc
Old Aug 12, 2003 | 06:41 PM
Irocster's Avatar
Car: 1989 IROC-Z
Transmission: 700R-4
Wouldn't you at least have to remove the drive belt?
Old Aug 12, 2003 | 06:53 PM
mace87's Avatar
yea use a 1/2 inch socket prybar on a little thing with a spring on it. and take the drive belt off then you take off the bolts and hoses. you do not need to take off your alt. or anything else.
Old Aug 13, 2003 | 08:57 PM
MdFormula350's Avatar
i took my air intake off, lossened the water pump pulley, took the belt off, took the pulley off, unbolted the hose to the pump, unbolted the bolts to the pump, cleaned off the engine block, used some sealer and new gasket installed new one and then reinstalled the reverse way.
Old Aug 13, 2003 | 09:00 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Thx guys. Got it in, started it up, and coolant is streaming out the bottom of my engine. Its dark out, and I give the **** up for today
Old Aug 21, 2003 | 07:17 PM
Dr G's Avatar
Did you eventually get the job finished 'IROCThe5.7L'? Which model of waterpump did you use?
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
