Fan switch: If you can't find the green wire..
Old Aug 15, 2003 | 10:34 AM
cael's Avatar
There are 3 relays on my '91 Z behind the brake booster in an L shape. The middle one is the fuel relay, shorting the green wire to ground makes the engine stall (good for a kill switch maybe?). The driver's side relay (which has a green/wht wire) controls the driver's side fan; run it to ground to turn that fan on. The relay on the passenger side, turned 90 degrees facing the engine, was the secondary fan relay. It had no green/wht wire. You need to run the GRAY wire to ground to have the passenger fan kick on.
With one fan, 180* stat and two tranny coolers for the air to get nice and hot through before it hit the radiator in stopped traffic (95* in the noon sun), my temp was a steady 220.
With both fans, my temp stays at the line between 100 and 220 regardless of if I'm moving or not.
I don't know if this was posted, but I don't recall ever reading a post about a gray wire and I abuse the hell outta that search button
eightsixseven
Dec 16, 2024 01:50 PM
Steve78LT
Feb 24, 2016 12:15 AM
db057
Sep 4, 2015 07:57 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
