Help!
Old Aug 27, 2003 | 02:25 PM
My86TransAm's Avatar
Help!
Ok, so I've been having problems with keeping my car cool. I've heard that my fan should come on at 225 degrees, but it comes on at 240, way too hot. I went the auto parts store and the guy said because its summer, its normal for this to happen. I'm pretty sure its not. I was thinking about buying a jet fan switch, but it says for dual fan applications only. According to pontiac, my car should only have one fan. SO, what can i do? Is it safe to install the Jet Switch, or should I convert to dual fans and then buy the switch?
PS- its an 86 Trans Am 305 TPI, A/C, single fan. And I have already replaced the coolant temperature sending unit.
Old Aug 27, 2003 | 03:08 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
You can install the switch. It just means it's heavy-duty enough to handle 2 fans. I'd definately go to a 2-fan setup. You should be able to get all the stuff from a dealer, Junk yard, or a great place to check is E-bay. Search on 82-92 Camaro (my favorite) Oh, it sounds like your switch is fried. It should come on at the rated temp regardless of the outside temp.
