89 Formula leaks Antifreeze, not heater core or radiator
Old Sep 4, 2003 | 09:02 PM
91GunmetalRS's Avatar
It looks like one of the hozes is leaking by the Overflow tank. I do not know which hose it is. It could be the overflow tank is cracked or something. My problem is that I don't have any hose diagrams to see where the hoses go by the overflow tank. If anyone has an idea of what might be wrong or a diagram of the hoses and overflow tank it would be helpful. If it helps, it leaks on the right side if you are facing the front of the engine right on the frame.
Old Sep 4, 2003 | 09:10 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
it could be the upper or lower heater hose, mine did that, annoying
ill email you a picture of my engine with the hose i replaced, to see if thats the one you have a leak on.
Old Sep 6, 2003 | 10:15 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Did you check your water pump? There's a small weep hole at the bottom of it that leaks coolant when the seals go bad. When it happened to me, I didn't think the water pump at first cause it was kinda leaking towards the passenger side of the car, but what was happening was, it was coming out of the pump and running down the lowers coolant hose towards the rad at the bottom.
Tom
Old Sep 6, 2003 | 11:11 PM
I know it's not the waterpump, because it went bad on my Camaro(it leaked because the bearings inside wore out). It leaks right next to the overflow tank, and it doesn't overheat or lose fluid in the radiator. I found it out when I popped the hood and saw the overflow tank was empty. So naturally I filled it with antifreeze. About 5 min later the antifreeze was leaking from what looked like it was comming from the overflow tank and dripping off the frame. So I'm pretty sure its a return hose to the overflow tank or something, but if somebody had like a diagram of the hoses and overflow tank it would be helpful. I can't find it in my camaro chilton repair manual.
Old Sep 7, 2003 | 12:58 AM
Engine: 350ci
the over flow tank has a hole or the hose has a hole, from what you describe, take it off and look at it
Old Sep 7, 2003 | 02:06 PM
MdFormula350's Avatar
yeah it could be cracked where u cant see it, its only two bolts that hold it to the body. you could try to epoxy it if the plastic is cracked.
Old Sep 7, 2003 | 04:38 PM
All right, I'll give it a try soon.
Old Sep 7, 2003 | 05:19 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Just don't forget that if you go to take it off, one of the bolts that holds it on is in the wheel well.
Tom
Old Sep 8, 2003 | 07:18 PM
Engine: 350ci
i have a problem similar i just found it
check the area next to the distributor on the driver side when the radiator is full warm up the engine and check for leakage on the manifold area, i have a carb, dont remember if you do but look there, mine is shooting coolant from there like a giant squrit gun!
Old Sep 21, 2003 | 09:26 PM
i know it took a while, but I've finally gotten the overflow tank off. This is the first time in about two years that I got a day off work on the weekend, so I spent it doing work on the car. The previous owner tried to fix a huge crack at the bottom of the overflow tank. You can get one on ebay for like $20. the wierd thing was that he spent the time to get the tank off, why didn't he replace it? The thing obviously had a leak, so for now I've got to find an overflow tank. If anyone in the Chicago suburbs has got one, I'll pick it up and will pay$. If not there's always Ebay.
Old Sep 21, 2003 | 09:28 PM
There's an overflow tank for $5 on Ebay. SWEET!!!!!!!
Old Oct 14, 2003 | 08:19 PM
well, lost the auction, but epoxy and fiberglass did a good job of sealing it up.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
