Sorry if this is a repeat...
Old Oct 14, 2003 | 10:35 PM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
Transmission: 700 R4
Can I use a 91 firebird radiator in my 85 TA? If they're totally different I'll keep looking, but if I can use a free one I will
Old Oct 15, 2003 | 06:00 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Should be the same, you don't mention whether it's an auto trans or not. Just look to see whether its got the trans cooler fittings in the right place otherwise it should fit right in. More infor always helps. Quick tip, try www.acdelco.com when crossing over parts. If the parts sub over to the same number it's a go. They also give you pictures of the common parts.
Old Oct 15, 2003 | 10:16 AM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
you know, i didn't even ask the guy if it's auto or manual...it's his parts car, and i know his other one is auto, so i assumed. hmm, i'll check. thanks for the advice.
83 Crossfire TA
Fabrication
Jun 22, 2013 08:05 PM
TennesseeIroc-Z
Apr 30, 2013 11:21 PM
Roger Davis
Nov 20, 2011 11:55 PM
FlippindaBird
Carburetors
Sep 8, 2009 01:28 PM
dojo55
Jul 22, 2006 09:25 PM
