LG4 Q's
Old Aug 4, 2009 | 10:15 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
LG4 Q's
Hey i know some of these questions are probably here somewhere but i could not find answers so sorry if they repeat...
What needs to be done to remove EGR from an LG4?
How do i delete the A.I.R. ?
I would like the car to function as it does now with no codes thrown, no check engine light.
Would a LT1 vette cam be a good choice for a mild LG4 build with vortec heads or would a 350 Ram Jet Cam be better... how would these work with the stock ecm?? reason i ask is i have access to both of these and they are free... i was advised to use a ZZ4 cam but i would have to buy one and then upgrade the springs i believe the stock springs would work ok with the lift on either of these cams...
also i would like to upgrade to true roller rockers, 1:6 or 1:5 better with one of these cams???
here are the specs on my engine... stock vortec long block edelbrock intake stock carb/ engine management...
also i have a stock in tank and mechanical fuel pump
thanks for any and all help
Old Aug 7, 2009 | 09:49 PM
Re: LG4 Q's
no takers?
Old Aug 7, 2009 | 09:50 PM
Re: LG4 Q's
if theres a sticky somwehre on these Qs someone please just point me in the right direction and delete this post, thanks
Old Aug 8, 2009 | 09:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: LG4 Q's
For the AIR - just have to plug the ends of the tubes that come off the exhaust manifolds, and cut off and plug the line that runs to the cat. As far as belt routing goes, you're on your own - it's a v-belt car right? I have serp belts, and not sure of the v-belt setup.
EGR removal requires a block off plate - should be available at Summit. EGR also uses a vacuum line that will have to be plugged or capped. EGR removal will probably throw a code.
Cams I'm no expert on.
Roller Rockers can be expensive. I used a set of roller-tip rockers once, and they were a nice compromise for the price.
Not sure how your ECM will react to various cams, or higher lift (ie 1.6:1 rockers).
Old Aug 9, 2009 | 03:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The LT1 cam has been used by many as an upgrade for LG4 and LO3 engines. The ECM will be fine with it.
If you leave the EGR solenoid plugged in, it won't set any trouble codes.
Of course, removing A.I.R. and EGR is illegal in all 50 of the United States for vehicles driven on public roads.
Old Aug 9, 2009 | 08:09 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: LG4 Q's
is there a downside of the lt1 cam in a LG4 or just an all around improvement?
Old Aug 10, 2009 | 08:31 AM
Re: LG4 Q's
yeah its not gonna be getting driven legally on the street anymore lol
thanks for the info on the egr block off, and the lt1 cam will be better then the ramjet so good stuff... 1.6 roller rockers ok tho?
Old Aug 10, 2009 | 08:32 AM
Re: LG4 Q's
anyone wanna venture a guess on HP and TQ???
Old Aug 10, 2009 | 02:20 PM
five7kid's Avatar
What do you have for exhaust and air cleaner?
Old Aug 11, 2009 | 10:38 PM
Re: LG4 Q's
as of right now, stock manifolds with 3"cat less exhaust FM muffler... edelbrock proflo 1000 air cleaner but i will be putting a dual snorkel on when i get it back from sandblasting, and im going to be getting headers and a custom dual exhaust in the near future so ...
Old Aug 24, 2009 | 12:59 PM
Re: LG4 Q's
no guess'?
Old Aug 26, 2009 | 11:54 PM
1qk4mula's Avatar
Car: 91' Formula/88' Formula
Engine: 5.7L TPI/ 5.7 zz4 with mini ram
Transmission: 700r4/Stock T5
Axle/Gears: 10 bolt 3.23 /9 bolt 3.70
Re: LG4 Q's
What year is your LG4? cause all lg4s use flat tappet cams. the lt4 is a roller. I know the 87 lg4 is a roller block so u would need roller lifters, hold down spider, and the things that hold the lifters in place, (i cant remember what they're called)
But i think with ur mods and stock cam i'm guessing 230hp/260tq
Old Aug 29, 2009 | 11:19 AM
Re: LG4 Q's
so your saying my 87 305 did not have a roller cam? its a vortec block and heads tho BTW but 230 260 sounds pretty stout for a LG4 to me so maybe 260 /290 for the 5.7?
Old Sep 8, 2009 | 10:32 AM
Re: LG4 Q's
bump
Old Sep 8, 2009 | 01:28 PM
five7kid's Avatar
'87 LG4's had roller lifter cams.
RazorN8
Jan 7, 2022 11:44 AM
podiatra
Aug 31, 2015 09:53 AM
ambainb
Aug 29, 2015 12:43 AM
85ws6TA
Jun 27, 2001 12:25 PM
Conv389drv
Aftermarket Product Review
Dec 12, 2000 12:46 AM
