Tranny Coolers.. Which one to use? what size?
Car: 02 Z28, 78 Z28, 86 Iroc
Engine: 346 LS1, 350 Goodwrench, Vette 350
Transmission: M6, T 10, 700 R4
Their are a lot of companys out their that make tranny coolers. Which one do you guys have in your 3rd gen's and what size did you buy? What comany has the best one, or does it make a diffrence?
Car: 89 GTA
When I installed a tranny temp guage I did it when I change the tranny fluid so I had the pan off. I bought a temp guage and senser at carquest. I drilled hole in the pan and installed the senser which came with a brass fitting but i bought a steel fitting so it could braze it to the pan and installed the guage under the dash. I put in a tranny cooler shorter after. A believe it was a medium sized cooler but it probably wouldnt hurt to get a smaller since im not pulling anything. I also installed the cooler before the radiator so the tranny fluid would have a chance to warm up.
1989 Trans am 305 TPI Auto, 2.73 rear, K&N filter, underdrive pulleys, air foil, tb bypass, low restriction exhaust
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i bought a haydens from shop that was going out of business. an dit was the 2nd largest one. i think likre 19000lbs. or somthing kike that but i could be wrong.
its around 13"x8" thats just the fins.
