Thermostat housing gasket and bolts.
Old Oct 5, 2003 | 12:40 AM
joshwilson3's Avatar
Old Oct 5, 2003 | 01:16 PM
David Trimble's Avatar
Can't help you with the bolt size for the housing, but as a word of caution- if you use steel bolts and you probably have a factory (or aftermarket too for that matter) aluminum intake manifold, you want to use antiseize compound on the threads. I made the mistake of removing and reinstalling the thermostat housing bolts on my '84 305 once without compound and when I went to remove them again a few years later found that the threads had seized. Snapped off the heads of both bolts- wound up having to have the holes redrilled and tapped......
Bubbajones_ya
Jul 6, 2024 08:32 PM
Stryker412
Sep 20, 2015 06:59 PM
armybyrd
Sep 15, 2015 06:06 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
hdis2002
Sep 8, 2015 02:52 PM
