flush and now high temps
Old Oct 8, 2003 | 05:12 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
I just fluished my coolant out today and I think I made a few mistakes......
First i didn't get the water out of the block. I just threw the garden hose into the thermostat opening. It ran clear out the radiator drain plug after a while. (mistake?)
I calculated the total capacity to be slightly mroe than 4 gallons. (not mistake)
I bought a 195 degree 'stat because thats what I thought was in there. There was a 160 degree stat in there. I put the 195 in because winter is approaching (mistake?)
Now.... I went to fill it up, so I put 1.5 gallons of antifreeze ina nd fired it up. I approached 2 gallons and it was full. I sure hope that the block holds 2 gallons. If not, I'm probably running near 90% antifreeze.
I took a small drive and the temps were hovering around 200-220F. This was higher than before, but I don't think I'm in trouble yet.
Old Oct 8, 2003 | 09:04 PM
MdFormula350's Avatar
yeah when filling anything up in the radiator, i am always using 50/50 all the time when refilling to get things right, then once the coolant is about to spill out the radiator i put the cap back on, then i fill the little tank up to full hot, then i check back the next day and most likely it needs alittle bit more in the little tank to keep full cold.
a 160 to 195 is a big increase something like 180 can be used year round.
Old Oct 9, 2003 | 04:33 PM
MechCD's Avatar
Engine: LO3, Vulcan
Welp, the heat sure isn't bad on those cold mornings.
I drove around for about an hour today is semi- city traffic and it never went above 220. I think I might siphon a bit of coolant out and add some clean water. I'll store the drained off stuff in another container to use if I need to put soem back in for whatever reason.
My thermostat housing gasket doesn't leak now!
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
wisemanz28
Sep 20, 2015 01:26 PM
corey8084
Sep 17, 2015 02:56 PM
DARKmj16
Sep 9, 2015 04:07 PM
