Steel or With plastic sides
Old Oct 26, 2003 | 10:47 AM
StormShadow's Avatar
Car: 91 Camaro Rs
Engine: 305 tbi
My radiator just went and I called up ABC and they said they had two different ones I could use. One that's completely steel and on that has the plastic ends. Price only differs by like 10 bucks so money is not the issue but I can't afford like a high quality one at this time period. What is the difference between these two and how much more does the all steel one weight? Which one do you guys think I should go for?
Scott
Old Oct 26, 2003 | 10:51 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ive seen plenty of plastic sided radaitors crack and break...
ive seen only a few metal ones spring a leak, and thoes were brazed shut for a fraction of the cost of a new one....
get the metal one.
Old Oct 26, 2003 | 12:06 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Plastic sucks for going through hundreds of thermal cycle, Last plastic radiator I changed for a friend had the neck come right off with the hose. Stewart Racing built a cooling dyno and did much research on cooling systems, Brass and Steel is the best combo for heat disapation, even over aluminum. AL just looks nicer, brass should be painted.
Old Oct 27, 2003 | 03:03 PM
Drakar's Avatar
Aluminum's big benefit is lighter
Old Oct 27, 2003 | 03:07 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ummm, NO.
the slight diff in weight between the 2 is more then made up for when you add in the fact that the alum one holds more water.... and water is HEAVY.
the alum aftermarket ones are generally more efficent because of the design.... NOT because of the material.
Old Oct 27, 2003 | 04:50 PM
kaupca's Avatar
Car: 92 Camaro RS
Get the all metal one. It will last a lot longer and can be fixed whereas the plastic cannot.
Old Oct 28, 2003 | 07:03 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
If U decide to get plastic, get Modine. They have a good warranty!
1992 Trans Am
May 10, 2023 07:19 PM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
scottmoyer
Aug 9, 2015 10:18 PM
MENINBLK
Aug 5, 2015 11:58 PM
