cooling fan wiring harness
Old Nov 24, 2003 | 03:43 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
my 86 ta has four wires going to the fan realy, i know that the red and red/black is directly to the fan one must be a ground, and the other two are togehter going to one port on the plug. can some clear it up for me and tell me what wires control what.
Old Nov 25, 2003 | 03:44 PM
MdFormula350's Avatar
this should help.
Old Nov 26, 2003 | 06:41 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
relay
Thanks for the pick you sent but i have a question. Where is the fan realy coil and the relay switch on a 86 ta carb 305 engine code H
Old Nov 29, 2003 | 08:16 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
the relay coil and relay switch are part of the relay, the coil is the part that when 12 volts is applied to it, closes the circuit of the switch
Bigwinn, if u trace the wires from your radiator fan, eventully you will find a black box that the fan wires connect to, there should be 2 or more other wires that come to it, that is the relay
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
Leggman1
Aug 6, 2015 04:15 AM
