Puddle of Water
Old Nov 28, 2003 | 08:20 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
Puddle of Water
I had dont the valve cover gaskets on my 83 camaro, and when i was taking the heater core hoses off, I broke it, so i replaced the heater core, cleaned up the mess, and put a new matt down. Now every time I lift up the matt there is water under it, not engine coolant but water, but it cant be coming from the heater core because:
A) it would be dripping on to the matt, and its not running behind the rug, because I took the heater core cover off again and theres no coolant leaking.
B) Its water and if it were coming from the heater core it would be coolant.
I cant figure it out because it cant be any kind of leak from the t-tops either because it would be dripping on to the matt not under it, If anyone knows what this is pleas tell me.
Old Nov 29, 2003 | 04:19 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
leak
i have the same problem that water is comming from the wiring harness entry way to the cpu. from there i don't know the only way is to take the fender off and seal the hole some kind of way. if you find another way please let m know
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Formula8r89
Sep 22, 2015 04:24 PM
