Intake coolant temp sensor
Old Dec 9, 2003 | 01:48 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
What is the part # for the coolant temp sensor that is in the intake? That is the one that sends a reading to the ECM right?
Reason I ask is that I think it is bad. When I put the car on the Auto-x-ray scanner the temp reading is in the 240* range when running normal. The indash guage is reading more on the lines of what I expect. In the 180* range. Even when the car has been sitting over night and I scan it before I turn it on, the coolant temp is in the 100* range. That is when the outside temp is 40*!!!
Old Dec 10, 2003 | 06:52 PM
MdFormula350's Avatar
yea not sure on the part number but advance auto parts carries them.
yea the coolant temp sensor is in the front of the engine / intake manifold, its the one that read the temp and tells the computer.
it reading that high i would suspect the pasengers fan being on all the time.
Old Dec 10, 2003 | 10:04 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Thanks!!!
So you think its just that the sensor is bad, and that is causing the problem?
Old Dec 11, 2003 | 12:08 PM
yeah i would think so: two reasons
1. its reading way off what your gauage says.
2. and you know thats its not really running that hot.
stalkier
Dec 6, 2015 11:25 PM
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
