relocation?
Old Dec 17, 2003 | 01:57 AM
Kandied91z's Avatar
relocation?
is it possible to relocate a set of heat controls on my 91? i don't have ac and rarely use the heat on my car so to have that whole section taken up bothers me. i would still like to be able to turn the heat on in the fall when needed though.
any ideas or suggestions?
Old Dec 17, 2003 | 08:08 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Run the switches into the ashtray. What are you planning on doing with that empty space left by the controls???
Old Dec 18, 2003 | 07:39 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
You need a 4 position switch and a cable slider for temp control. The four positions run the 12v blower power through the 3 resistors that are located on your heater box. You can go as crazy as you want by using a potentiometer and a servo motor for the temp control instead. Or you can change the geometry of the cable slide lever so that the slide travel is more compact in appearance. You may be able to find a compact servo system from a ford windstar van or some other donor. Using this system, the heater controls could be extremely compact. If you wish to retain the defrost gate and not just the heater, of course an additional servo will be required for that gate also. I like the idea of a custom console, but I dislike the idea of ditching the hvac in your car.
I have some opinions on cleaning up your engine bay also if you'd like to hear them. I know you are interested in show-quality installs.
Stop being so cheesy and secretive. There are many people watching that can offer advise that you havent even thought about asking.
Love the car...one of my top 3 for sure!:lala:
Old Dec 19, 2003 | 02:08 PM
Kandied91z's Avatar
cheesy and secretive? i just wanted to know if it's possible....i don't have a/c any more and i rarely use the heat but it ouwld be nice to retain it.
as far as suggestions i'm always up for them.....
Old Dec 19, 2003 | 03:10 PM
JMatlock88's Avatar
Car: 1991 Formula
hehe ya just referring to other posts
I'll drop you some mail sometime. Good luck with the project-- You have good taste. Say, are you planning on zoop sealing those parts that you're sending off to be polished? I've been fighting a loosing battle against oxidation.
Old Dec 20, 2003 | 02:38 PM
Kandied91z's Avatar
i have yet to see that product in action....i would like to try it on some smaller parts but i can't chance it on the wheels in case it turns out wrong. just alot of elbow grease.
Old Dec 20, 2003 | 06:35 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Get an overhead console and make the controls fit up in where the "reminder wheels" reside.
Old Dec 21, 2003 | 05:11 PM
Kandied91z's Avatar
i have ideas of where to put it i'm just not sure how to extend it? i just want to extend the heater portion since i don't have a/c. i suppose there isn't really any easy way to do this is there?
grngryoutmyway
Oct 18, 2016 05:48 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
89newfun
Sep 16, 2015 09:28 AM
