coolant temp switch
Old Jan 15, 2004 | 06:38 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
coolant temp switch
i have a 86 trans a, 305 carburated enging my temp gauge is all was past the 220 mark new water pump,radiator. thermostat. and temp sending unit and passenger side cooling switch the fan dosnt come on uless the a/c switch is on and the temp stays around the temp i mentioned earlier fan relay is good also have i missed something
Old Jan 15, 2004 | 07:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Is this while driving and does your car have the air dam installed on it. As for the fan coming on with the A/C switch, that is normal.
The Trickster!!!!!!!!!!!!
Old Jan 15, 2004 | 07:59 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
reply
yes i know its normal for the fan to come on wiith the a/c on my problem is its not commimg with the gauge reading 220 and above. my thermastat housing had two seners one is a vacum and the other has wires attatched
89 formula TPI
Oct 6, 2015 08:40 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
86IROC112
Sep 11, 2015 04:04 PM
85Special
Sep 3, 2015 04:21 PM
