fan relays
Old Jan 30, 2004 | 09:37 AM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
fan relays
anybody know the difference between the relays I can find @ Parts America.com vs the hayden relays on Willie's write up? Is it just the advantage to have dual fans each going off at different temps?? WIth stock replacement relays, both will go off at the same time at the same temp?? Am I right or confused?
Old Feb 2, 2004 | 09:59 AM
hitman's Avatar
anybody??
I would think some has an idea about this.
Old Feb 2, 2004 | 08:58 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Relays are relays, they have nothing to do with activation temps.
The purpose of a relay is to isolate your switching device from large current sources -- think of it as a "remote switch".
Most automotive relays are single pole, double throw (SPDT) which means that there is a normally-open, and a normally-closed side, in addition to the control terminal. As far as the SPDT automotive relays go, usually the differences revolve around the current rating, and whether or not they are waterproof or not.
HTH,
Old Feb 8, 2004 | 10:21 AM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
the Hayden is more than just a relay
If you are talking about just the relay, then any relay of the same power rating will do. But the Hayden kit is more than just a relay, it also includes the temp sensors to trigger the relays.
In a stock configuration, the fans are controlled by seperate relays with different triggers. If you rewire them, they can go on and off together.
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
