Coolant Spraying out from somewhere, HELP!
Old Feb 8, 2004 | 02:54 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
Okay this has me totally stumped. There is coolant spraying out from somewhere and hitting my serpatine belt and getting on my hood liner. It's not a big problem as my cooling system works great but I do have to regularly add coolant to the system.
I have looked everywhere and can't see it coming from anything. All the hoses and fitting a perfectly dry.
Has anyone else had a problem like this?
Old Feb 8, 2004 | 06:44 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i had somthing happen kinda like it. i redlined and blew apart a hose. the one that goes into the trottle body. it broke and shot coolant ono my belt, spraying it everywhere. i had to fill it up, start her to find out it was that.
Old Feb 8, 2004 | 07:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I had that happen to me tonight and I found it was coming from the hose that connects the heater control valve to the throttle body.
Old Feb 9, 2004 | 12:43 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Theres a weep hole on the bottom of the pump that will leak when it goes bad might want to check that.
Old Feb 14, 2004 | 07:21 PM
JerseyIrocZ's Avatar
Car: 89 Iroc
Engine: 5.7 liter (L98)
Transmission: TCI 700r4
its going to either of the two fill it up then stick your head in there and see where it is probably the water pump
Old Feb 14, 2004 | 07:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Old Feb 18, 2004 | 11:59 AM
Car: 89 Iroc
Originally posted by Trickster
the
Old Feb 18, 2004 | 12:06 PM
Engine: peanut LB9
i finally got what jersyroc said. after about 2 weeks lol
Old Feb 20, 2004 | 09:00 PM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Engine: (LO3) 305 TBI
Transmission: 4spd
well i dont think its the heater control that sits above the belt. check hoses for punctures. If its sparyin out u can always open the hood and give the car gas from under the hood. and try different things.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
