pass. fan not working
Old Mar 4, 2004 | 04:03 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
ive searched this topic but could not find thew exact answer im looking for. my passenger side fan does not come on. i know it is activateb by that a/c sensor in the pass head between 6 & 8. my question is, when working properly, what temp should this fan turn on? i know the driver's side turns on at around 230 via the temp sensor. i am almost positive the pass side fan should turn on around 180 but i cant find any info on it. also, does anyone know what could be causing the fan not to run? bad motor or relay perhaps??
thanks
Old Mar 4, 2004 | 10:04 PM
BottlesR4Babies's Avatar
Car: 91 Z28
Engine: 350 TPI H.O.
i just had the same exact problem. its the part of the ecu that controls that fan is busted. same thing happend in my 91 z28. so i have that fan rigged to a switch without using 12 volts. i have it so it grounds the relay switching on that fan.
quick fix
Old Mar 5, 2004 | 07:54 AM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
I took my '1 Formula to the dealer about 6 weeks ago on this. The fan on the left would not come on until it gets to 220, and the dealer checked everything and they said it is normal and the second fan will not come on until it hits that temp. They put in a 180 therm. in it to and it runs cooler, but not like my other '91 with a factory 350. It runs 180 all the time. Only in severe traffic it will climb to 220, I am confused on this too. Andy
Old Mar 7, 2004 | 03:16 PM
MdFormula350's Avatar
actually its an a/c pressure switch on the a/c line and the fan switch which is between 6 & 8 cyclinders.
stock its high like 234 or something like that.
yeah around 227 ish for the drivers fan, works of the coolant temp sensor on the front of the engine.
get alittle temmp fan switch which will turn on like around 200 and you should be all set.
reasons for hte fan not to work burnt motor, just hook 12 volts directly to it to see if it works.
bad relay could be another reason. if ur drivers side works just swap relays and see if its works.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
