fixing rad tank leak?
Old Mar 7, 2004 | 04:50 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
The passenger side tank of my rad has a little hole through which the coolant pisses out when hot. A new rad costs me minimum of $225. Are there any cheap fixes for the plastic tank? I'd rather do a cheap fix first before replacing the rad.
Old Mar 8, 2004 | 05:33 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
GM used to sell a high temp epoxy for tank repair. You can buy just the plastic tank thru www.acdelco.com use that site for the part number then you can get it from any AC Delco retail outlet. It's a very common problem, if you are careful you can fix it yourself but your best bet is a rad shop. Usually for 50-75 bucks they will replace the tank, clean the core and guarantee it. If you do it youself the tank runs around $35 or so.
Old Mar 15, 2004 | 05:08 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
I had a new tank put on mine for $75.00 not bad for parts and labor.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mike_c
Aug 27, 2015 04:32 PM
