Radiator drain=Plastic??
Old Mar 9, 2004 | 06:15 PM
Jurrel's Avatar
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
Okay I have to know if this is the case with all new cars or if my radiator was replaced with something cheap! I just changed ther adiator fluid recently and noticed the petcock/drain valve is a plastic screw?? What in the heck are they thinking? Im afraid to go to tight with it cause I KNOW its gonna break if I put to much pressure on it.
Are all firebirds cursed with a plastic drain valve/screw? If so whats a good, not to expensive radiator with the old wingnut style to replace it with?
Old Mar 9, 2004 | 07:02 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Mine is plastic. No problems with it for 5 yrs. now
Old Mar 9, 2004 | 07:04 PM
86IROCKET-Z's Avatar
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
My 86 and 87 IROC's have plastic drain screws..
I think most thirdgens came with them.. I know that my Friend's 94 Camaro has a metal one..
I know what you mean though.. every time i drain the coolant, i'm really careful, but it's never leaked or anything..
Old Mar 9, 2004 | 09:34 PM
Jurrel's Avatar
Car: 1984 Firebird
Well I think this is the original rad in the car, it looks it, so it would be a 20 year old peice of plastic so Im not to sure I like it....also I have a small leak someplace in the cooling system...Im betting on that plug...
Old Mar 12, 2004 | 08:58 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
my 83 still has the original rad - the drain is metal
Old Mar 16, 2004 | 07:36 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
My 88 IROC has a plastic drain valve, and the side tanks are plastic as well. No problems with the drain valve busting. I just flushed the system it works fine and doesn't leak. What does suck is the cheapassed plastic end tanks that crack and **** coolant all over.
Old Mar 28, 2004 | 08:13 PM
Clint E.'s Avatar
Car: 88' Iroc
Engine: 383
I just pulled my engine and when I went to drain the rad I just touched the drain plug and it broke off in my hand!!!!!! That could have left me on the road!!!
Old Mar 29, 2004 | 10:49 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I've had one break as well.
Went and got one from the wrecking yard.
They stock the popular sizes at Auto Zone/ Kragens now.
-Rich-
jrdturbo
Mar 31, 2016 02:58 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
raymondandretti
Sep 27, 2015 06:43 PM
lanceflame44
Sep 25, 2015 12:28 PM
Night rider327
Sep 25, 2015 04:19 AM
