fan to water pump bolts
Old Mar 22, 2004 | 01:23 PM
DustBunny's Avatar
Car: 83 Camaro Sport Coupe
Engine: L4
Transmission: 200c
I have an L4 83 camaro and I'm replacingthe water pump, but I can't get the bolts off of the old water pump wheel. I got the pulley and the fan off, but I can't get the double sided bolts off of the old one so I can attach the fan and pulley to the new one.
Any help?
Old Mar 22, 2004 | 06:21 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
spin two nuts on one stud, tighten them against each other, then use a screwdriver between two other studs(they are studs, not bolts) and use a wrench on the bottom nut and they should come right out, loosen them all this way first(so you can still use a screwdriver to hold it) then when they are all loose, take them all out(once they break loose, they should screw right out, not always, but most of the time)
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
