Can someone
Old Mar 30, 2004 | 05:01 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Can someone
Please tell me how to wire up my fan to run on a toggle switch? I going racing this weekend and need my fan working.
Old Mar 30, 2004 | 07:24 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
TTTTTT
Come on guys .....no one can help
Old Mar 30, 2004 | 07:37 PM
RebelTillDeath3's Avatar
Car: 92 Camaro
With wires, a switch, and electricity.
Old Mar 30, 2004 | 09:01 PM
elcamin0_77us's Avatar
Car: 77 El Camino
Engine: 355 Converting to TPI
Transmission: Converting to 4L60/4L60E
If you are just wanting manual control:
You can install a relay to allow the toggle switch to control the voltage to the fan. The relay alows a smaller circuit to control a larger circuit. The following Links gives examples of how to wire in a relay http://www.rps4wd.com/tech/relays.htm & http://www.geocities.com/gdgo/f150a2.htm
If your fan(s) are not coming on then check out my reply to the following post: https://www.thirdgen.org/techbb2/sho...hreadid=231136
Bill
Old Mar 31, 2004 | 07:08 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
I think rebeltilldeath got it about right....
1 # Fit a switch!
2 # Run a wire from there to ground
3 # wire the otherside of the switch to splice into the same wire that goes to the temp switch in the passenger side of the block.
Thus you shouldn't need an extra relay, just use the one thats there already and wire the switch to be in parallel with the temp switch.
You make no mention as to why you need this manual control. If your current temp switch is faulty then try replacing it! If the current relay is faulty you'll need to replace it! If its just that you like having the fan on for the heck of it then do the above.
Si. :lala:
Old Mar 31, 2004 | 04:41 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
The factory setup isn't workingh right so I just needed a temporary way to get it working so I could go racing sat. Then after that I can fix it the right way.
Old Apr 1, 2004 | 04:32 AM
iroc-si's Avatar
The first thing you need to do is figure out whats wrong with it! Its most likely the temp switch thats gone, but if you don't know then you're going nowhere....
Try shorting the temp switch wire to ground (with the ignition on) if the fan fires then do as I described above for a toggle switch solution. If that doesn't work then you need to figure out if its the relay or the fan... follow elcamin0_77us advice as linked above.
Si. :lala:
Old Apr 2, 2004 | 11:42 AM
breathment's Avatar
have you looked at the wiring diagram yet?
Old Apr 2, 2004 | 08:08 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
sent you an email with instructions that I got from Willie on how to wire up a manual fan switch.
john
Old Apr 6, 2004 | 05:15 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Got it fixed. now it comes on with the key. Thanks for all the help
Old Apr 6, 2004 | 05:59 PM
White91GTA's Avatar
Engine: 5.7L TPI
What did you do to fix the problem
Old Apr 7, 2004 | 05:27 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
re-wired with a different relay. I went out and got a bosch relay.
