Going to buy a trans cooler
Old Apr 6, 2004 | 03:22 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
I got a 50$ gift certificate form summit...
so what cooler should i get? what are the best?
what does the numbers mean? how big should it be? quick connect?
i want to mount it infront of the radiator and bypass the radiator completly... what do you guys think?
Old Apr 6, 2004 | 03:34 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Going to buy a trans cooler
biggest you can get.
B&M super cooler.
you dont need quick connects.. its not like you're taking it on and off alot.
you should keep the radiator one and run the cooler in series with it.
Old Apr 6, 2004 | 07:50 PM
HamSpiced's Avatar
why run it in a series with the radiator?
i would think that the radiator would make it hotter then it normally would be,,,
Old Apr 11, 2004 | 05:03 PM
vwdave's Avatar
Run it through the radiator first so it gets cooled that way, then through the cooler, it gets cooled again.
I was looking at a dual circuit unit from Perma-Cool and putting a Oil Cooler in it.
Old Apr 11, 2004 | 06:43 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i got a TCI trans cooler and am happy with it. i recommend it to others as well.
toronto formula
Nov 10, 2015 06:17 AM
theurge
Aug 21, 2015 12:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Dquickshift
Aug 12, 2015 06:21 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
