fan does not come on with engine heat
Old Apr 14, 2004 | 07:20 PM
qcworm's Avatar
Car: 1987 IROC Z-28
Engine: L-B9
Transmission: 700R-4
my dual fan set-up is not functioning properly. the driver side fan works as intended but the other one does not work when it should. i checked the relays and they are fine. if you give the fan a ground it works but something is not telling it when to come on . any help?
Old Apr 15, 2004 | 01:16 AM
breathment's Avatar
what temperate are you running? can you give a little more info about this?
Old Apr 16, 2004 | 10:07 PM
qcworm's Avatar
Car: 1987 IROC Z-28
Engine: L-B9
it runs about 160 while driving. but when you sit still it will rise . i have let it go up to about 220 and it still wont come on. so i am stumped. i checked the relays and i think they are good. i put a new switch in it. that didnt help. if you ground the fan it will work. to do this touch the wire to the switch to anything. and the fan takes off. help please
Old Apr 16, 2004 | 10:19 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I was poking around at work a while back, and I looked up the stock spec for the secondary fan switch on a dual fan setup.. It was something like 238*...
I'll see if I can double check that and confirm that figure tomorrow (or if anyone else knows for certain??)
Old Apr 19, 2004 | 07:57 PM
rsn932's Avatar
i have the same problem w/ an 87 305 tpi
the passenger side fan never comes on but the drivers side one works fine
thirdgen88, id like a confirmation on that stock setting for the second fan to come on
any other input would be welcome
Old Apr 19, 2004 | 10:33 PM
thirdgen88's Avatar
Car: 1995 Corvette
Well, confirmation you have! I actually did some research today at work.. The stock radiator fan switch for a dual-fan system is a normally open switch that closes from 240*-252* (this is from the GP Sorensen specifications guide).. See my other post for optional fan switches...
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
kyle5647
Aug 15, 2015 11:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
