Fan problems please read!
Old Apr 16, 2004 | 05:51 AM
DustyWusty's Avatar
Car: 89 bird, 86.5 D21 Hardbody duringwinter
Engine: 305, VG30e
Transmission: 700r4, dunno the other one :)
Hey guys I was changing my spark plugs and wires the other day when I noticed that my temp sensor for the dash was unplugged...plugged that in works fine
i also noticed this ground type prong thing by the starter
so i left that alone and took a drive
I noticed my fan wasnt coming on, so i decided to ground that wire and wahla it came on
I tried plugging it back into the fan switch in the head after further investigating, no go, not even when the engine was HOT
so i bought a new switch put it in, cleaned off the connector with sand paper, put the wiree back in the new fan switch
still no go
since i have to drive the car i wired up a manual ground switch inside the car...any ideas what this could be? it works fine when i ground the wire
Thanks guys!
Old Apr 16, 2004 | 03:50 PM
bb576's Avatar
Car: 1987 iroc z
no idea. but were is that temp sensor located? my guage doesnt go on either. maybe thats the problem
Old Apr 16, 2004 | 05:03 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
The Temp sensor for the Guage in the dash is in the drivers side head between Cylinders #1 & #3
The Fan Switch is in the Passanger side head between Cylinders #6 & 8
There is also a temp sensor for the ECM located in the Front of the Intake manifold, just above the timing cover
and DustyWusty You might check the ECM temp sensor I mention Above. I think the ecm controls the fan turn on temp on a 1989 Bird, and if that sensor is bad, the ecm Dosen't know the engines operating temp so it won't turn the fan on.
Old Apr 16, 2004 | 10:17 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Well, if its TBI, I don't think the ECU has any control over the fan (it would be a single electric fan)... On my brother's 1991 L03, there is just the fan switch in the pass cyl head that controls the fan. The spec for the fan to turn on (this is stock spec for a single electric fan setup) is around 220* (222 maybe?)..
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
TA8487
Aug 16, 2015 12:21 PM
