Radiator Relay Problem
Car: 1985 Z-28
Transmission: 700R-4
HAD MY ENGINE REDONE FEW MONTHS AGO. SINCE THEN I HAVE BLOWN LIKE 5 RELAYS TO MY RADIATOR FAN, IT RUNNING ALL THE TIME. I ORDERED THE WIRE HARNESS CUZ ITS ALL BURNT AND "JIMMI-WIRED" WILL THAT HELP OR WHAT ELSE CAN I DO ?
THANK YOU FOR THE HELP"!?!?!??!?!?!?!?!?!
Car: 85 Z28
Engine: 305 LB9 TPI
Transmission: TH-700R4
i had this problem once, but my fan would not turn on. i changed the relay and it fixed nothing. my wiring was "jimmi rigged" too. the previous owner pulled the original out of the fuse block and just ran a security system from it i think. he ran a toggle switch from the front defroster, which i found because it melted the wiring that connected to the switch. i found that i needed a wire to run from the fuse block to the orange wire on the relay. it should fix it if this is the prob. tell me if it is something else.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 11, 2015 10:11 PM
