Jet Fan Switch
Old Apr 22, 2004 | 03:10 PM
jl0gue's Avatar
Car: 89 IROC
Transmission: 5 Speed
Jet Fan Switch
Hello,
I just recently bought a jet fan switch to go along with a new computer chip and stat, and I cant find the switch on the engine. I contacted Jet and they told me it was on the passenger side of the engine bettween 6 & 8. Im guessing its on the engine block? I was reading some posts here and I read that there was also a fan relay switch around the same place? If there is how do I tell the diffrence? Specifics on the location of the fan switch would be greatly appreciated.
Thanks.
Old Apr 22, 2004 | 06:42 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Fan switch
Get your car on ramps ,Slide under neath to the passenger's side of the block. Look at the side cylinder head between the last two cylinders wich are number 6 and number 8 cylinders. Its going to be kinda hard to see because the nose of your starter will be right lined up with sensor but it screws into the side of the cylinder head.
The easiest way to do this is to disconnect your battery then drop your starter and get it out of the way. then you can really see what your doing.
Old Apr 24, 2004 | 03:17 PM
jl0gue's Avatar
Car: 89 IROC
Thanks for the detailed description. I'm pretty sure I've located it now. Its between 6 & 8 right under the exaust manifold correct, right near the spark plugs? I saw another sensor under there that looked similar but was way lower, just above the oil pan lined up with the other sensor, and right in front of the starter, from your descripton that could be it also? the one up by the spark plugs has a black plastic cap which was not even on the sensor and exploded into 20 peices when I tried to put it back on. The sensor in front of the starter has a white plastic cap. At least I've narrowed it down to two possiblities now. Any help on which one it is would be great, Thanks.
Old Apr 24, 2004 | 04:27 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
You are correct on the location of the fan switch (the sensor with the black plastic cap, as you said). Other sensor that you mentioned (the one with the white plastic cap) is the knock sensor.
Old Apr 25, 2004 | 11:39 PM
robsgta's Avatar
location
Yes its between 6 & 8 cylinders on top the other sensor is the knock sensor wich is at the bottom of the block between 4 & 6 cylinders. You can also take the new temp sensor and make a visual comparison. Unfortuantely heat bakes the plastic housing wich surounds the pin in the centor of the sensor. I also used wire ties to keep the wires from wondering too close to my headers to keep them from frying.
Removing your starter will seem like a huge pain in the a$$ but it will make your job a breeze.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
