350 swap, computer is gone....how can I get fans to run off the engine temp?
Old Apr 24, 2004 | 05:08 PM
StealthElephant's Avatar
Car: 87' Iroc
Is it possible...I just read the thread where it said it's not good to run the fans all the time. When I did the 350 swap the fans where wired to "key on" power so they always run.
With everything from the TPI disconnected is there anyway to get the fans to work like they did from the factory? Should I run a remote switch so I can just turn them on once the engine warms up....once the engine gets up to ful operating temperature do they always run?
Old Apr 24, 2004 | 06:35 PM
86'Bowtie's Avatar
Car: Hugger Orange Camaro
What I basically did was run an electric fan, controlled from the
"foglight" switch, since I have no foglights anymore.
When I turn my car on(cold start only) I wait for the temp to get as high as about 140-150, then flip the switch.When I turn the car off, turn the fan off also.
It would be alot easier to get a relay that way it would come on at ideal temperatures, like the original.Just a suggestion,DUECE
Old Apr 24, 2004 | 07:43 PM
Car: 87' Iroc
Bowtie...well my only question was....the stock relay setup, did it simply wait until the engine hit the desired temperature and turn on and stay on or did it constantly shut on and off, on and off tp regulate the temperature.
I think I read somewhere the temperture control ran off the ECM...which I no longer have in use.
Old May 2, 2004 | 09:16 AM
CrazyHawaiian's Avatar
Car: too many ...
Spal carry's a kit that will do what you want. I don't think it works with the ECM in any way, but you should call Spal to make sure. The kit includes a wiring harness, fuse link, relay, and thermostat switch for different temps (180/195/etc). Its like $50.
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
armybyrd
Aug 10, 2015 09:23 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
gwade12
Aug 8, 2015 08:17 AM
